Nice report. Have you always used a 20 grade in that engine? Up until 2006 it called for 5W30, they made the change to 5W20 in 07.
Last 2 changes was on 0w20, but other than that its been on 5W30.
Originally Posted By: bigt61
Good run on that oil. How big is the sump and did it use any oil in the 8k? Thanks for the post.
Originally Posted By: Stillbreathing
Originally Posted By: Donald
Looks good. I would run 0W30 or 5W30 if that is what is spec'ed.
The jeep is back on 5W30 qsgb. I ran the car on 0w20 to see if it would of caused excessive wear on a nonspec'ed car.
Well you got you're answer.
A good report.
RP 0W-20 held it's viscosity with no oil shear.
The reason engines that were once spec'd for a fuel conserving 5W-30 dino have no problem running a 0W/5W-20 today is because the base line or minimum standard for motor oil has improved a lot in the past 30 years.
In other words, you may have been running a grade lighter than what was originally specified but in actuality the oil was likely heavier at the end of an OCI than some cheap 5W-30s were in the past.
