Originally Posted By: Avery4
I have a 2000 Dodge Stratus 2.4l with 200,000 miles. Are there any easy ways to gain power? Already using synthetic oil and trans fluid, cold air intake, plugs and wires, clean fuel system, new fuel filter and no mechanical engine problems or maintenance due. Each cylinder has 180 psi of compression, give or take 3 psi. Any easy mods fore more power?
OK, what is your goal? Your car is a 15yo grocery getter, nothing more. Do you want a little more pep at a traffic light? A little better gas mileage? Define your goal. Someone else mentioned, the car is heavy. Anything you can do to reduce weight will help some. What are you carrying in the back seat, in the trunk. I have seen cars with 200lbs of stuff in the back seat, another 300lbs in the trunk, Another 50lbs of dirt in uc, That's 20% of the car's weight.
