My girlfriend's 2005 Ford Escape with 140,000 miles just decided to throw a check engine light, and since she just spent $900 to have her exhaust replaced, she was a little concerned the shop damaged something. Muffler shop said the computer had to "get used to the new exhaust" and the light should go away on its own, which sounded mighty fishy.
Finally got a chance to look at it, and my scan tool showed p0054 and p0141 codes, which pointed to a problem with the downstream oxygen sensor heater circuit. When I looked underneath, I saw the cat is up near the exhaust manifold, and the muffler shop didn't touch the cat or either oxygen sensor. Wiring wasn't damaged. They just bolted up a new exhaust after the cat and downstream sensor. Since it was 140,000 miles and the sensor was original, I chalked it up to coincidence that the sensor decided to quit then, and she got her mileage out of it.
Cleared the codes, and at least the scanner is showing sensor data from the downstream sensor. Question: What do the fluctuating voltage readings mean? Second, the MIL light is off, and at least after a couple of drives she's saying it's still off. I would think if there was still a problem it would have lit up by now. Lastly, I went with a Bosch sensor from Autozone. It looked slightly different from the original, but the PCM seems happy with it so far and had no trouble installing it. I've heard conflicting reports on Bosch sensors, are they unreliable?
