Maybe customers complained about OMG my car is leaking so they set this up so the condensate might evaporate to steam instead?
I noticed my cheezeball $99 walmart window AC splashes the condensate on the fan and this flings it up on the condensor where it then evaporates, taking heat from the fins more efficiently than fanned air alone. It sounds like a gargling snoring mess all night.
Before I researched it, I drilled a hole in my Sharp window A/C unit to better drain the condensate, thinking something was wrong with the drainage, as-is. The unit only ever made a very slight water-splashing noise (barely perceptible) while running, but it would sploosh after each shut down.
So, while I do believe that the spraying of cold condensate (from the evaporator, which drains down toward the condensor) does improve efficiency, it is quite annoying.
I haven't drilled a hole in the second, identical A/C unit, but have noticed one benefit to doing so: when it comes time to removing the A/C unit for winter storage, the amount of water in the unit is minimal. The one upstairs, which hadn't been drilled, had to be held at an awkward angle to drain, through it's built-in drainage, for a very long time, it seemed.
I know you're joking when you explain the drain to atop the exhaust, but, who knows, maybe you're on to something! haha
