Has the engine used any oil, up to this point, since the work was done? If not, it IS run in and the whole argument is moot.
If it has, then you could consider using less expensive conventional oil for the next OCI, more to limit money spent, than any concern about it not running in properly.
When it stops consuming oil, or when consumption stabilizes, stops decreasing, that would be the best time to switch to synthetic.
Which begs the question....Do you know that the dealer didn't put synthetic in it, when they did the work? It may truly be a completely moot point.....
