The defendant here is a 1999 HD 1200 sportster that has about 16k on it, and has been grounded for about 6 years.
I went through the basics, and drained the oil ( no oil was left in the tank, just sludge and water, I imagine gas or whats left of it), washed the air filter, drained the gas ( my beretta really hates life right now with the stuff mixed into the gas tank
). After soaking the top of the cyls for a few days with ATF, I proceeded to crank the engine over w/out spark plugs in. It moved, lethargic imo, but I have no clue how a twin acts as I only have dealt with my Yamaha. Put the plugs back in and click click click..great. Pulled the rear cyl plug and cranked, eventually starting the bike. It holds idle in cyl 1 (front) but dies as soon as I plug the spark plug hole. Can't crank the engine past the compression stroke on cyl 2 even with the plug removed from the cyl 1.
Process of elimination obviously the thing isn't seized, it is NOT THE BATTERY. I was working off a 650cca battery from my jeep, and then tried from the running beretta with identical results. To make the poor thing crank with the 1 plug I had to disconnect front+rear lights, and am using 5w30 oil in it while working with temps
My conclusion so far is that maybe the cyl 1 has a poor compression, and the starter is oxidized and has only enough might to turn past low compression piston, not the other one, and definitely not both. Low compression is likely since the oil was loaded with fuel pretty good, it was nice and smelly in the filter, and the gunk in the tank.
I plan to pull the starter and tear it down to clean it ( if needed) next, right after I do a compression test on cyl 1,and if God willing on cyl 2.
What do the knowledgeable people of BITOG can suggest I do with this thing? I would like to get this thing running and try motorcycles from a cruiser perspective ( the R1 is the only bike I ever rode).
