Car is a 2006 Miata with 10x,xxx miles on it. Car was purchased used with 70k miles. Never had a rear wheel drive car before so I didn't even know what the differential was. So I dumped the fluid in the diff at 107k miles and it was dark and the magnet on the drain plug had a lot of fine metallic particles so I assume it was factory fill. I put SuperTech Synblend 75w-90 back in it and drove a few hundred miles and drained-and-filled again. The oil that came out was again dark and metallic particles were present on the plug. I just thought it might be from whatever old fluid that didn't drain out. Then I did drain and fill #3 after a few hundred more miles and it was still dark, which surprised me since the new gear oil is almost clear. Ultimately I will put Valvoline Synpower 75w-90 in it.
Is it possible for a differential to form sludge from running on the same fluid for too long? Or is it normal for the fluid to turn dark that quickly? Should I keep doing drain and fills until I notice the fluid coming out looks cleaner or should I just put the final fill in and not worry about it?
