Originally Posted By: WellLubed
I'll continue to run LM, and at some point, I should start sending oil samples in to Blackstone for analysis, to monitor rod bearing wear. The car is only at 58k miles and doesn't get driven particularly hard, so it will probably hold up a long time.
Thats also part of the problem with these engines, too many people are 'nice' to them, leading to excessive blowbye. They're a [censored] race motor put into a streetcar. They need to be warmed up gently, and then drive the living [censored] out of them once oil temps are where they need to be (which is rather quick, oil temps warm up to 160+ in summertime in just a few miles.
The shop I work for has a customer who owns an E46 M3 GTS3 car that we put together last fall, fresh rod bearings on an otherwise stock, ~100k+ motor, and has won literally every race he's been in. It's been running Redline 40wt race oil, Blackstone analysis has been great.
