Motorcycle tire gauge
N.C.
My 5 year old Bikemaster 0-60 lbs dial gauge I bought from Cycle gear stopped registering anything recently. I would like a small compact gauge that reads 0-50 lbs. My valve stems are hard to reach and the next time I need tires I'll have the 45 degree stems installed. And don't want to pay more than say $25 to $30.
I have 90 degree stems on my Triumph. Night and day better than the old straight ones on my Yamaha. I just tuck one of the small SLIME brand mini gauges from Wal Mart in a small storage compartment where my fuze puller tool was.
I use something very similar to the Autometer 2160. it holds the pressure until you release it. mine is the ford motorsport version, but very similar. I like it ALOT
Everything I need for a trip is carried in a modified Chase Harper tank bag...
The Chase Harper rest on my home made aluminum tank bag bracket...
Tank bag rest upon the bracket and does not in any way touch the
expensive $2,500 aluminum tank...
Mr.RC45's tank bag contents:
1 Home made aluminum chain adjuster spanner
2 & 3 BMW tire repair kit
4 tape measure
5 fuses
6 pen
7 flashlite
8 razor
9 digital infrared thermometer for tracking tire temps
10 digital air pressure gauge
11 Rolaids (CHP gives me heartburn)
12 Brown Bomber (Advil)
13 home made tool to access tail cowl storage space
14 5mm allen... spare mirror screw... cross point tool...
15 525 master link...
16 Home made collapsible lift to levitate the rear tire in order to
lube my stinky chain every tank full of gas... (my belt drive
conversion will eliminate this silly stuff...)
Total weight 2 pounds 5 oz
Stand extended...
Stand in place...
I bought the Joeracing #32307 5-60 dial gauge after researching several different gauges. It has a 17 inch hose with 2 different chucks, one a swivel, a bleed off feature, and a glow in the dark face. It was less than $25 shipped from Amazon and it got good reviews. It isn't as compact as the small gauges but it should fit nicely in one of my saddlebags.
