i found the most interesting thing when i changed the hydraulic filter in our new (to me) tractor:
number 1, the filter was collapsed and had "failed"
but that's not what was so interesting.
i found all of this pellet stuff crammed in the filter housing. it was all packed in the bottom of the housing around the filter (where the side is collapsed)
i can't tell what it is for sure, it looks like pellets for a wood stove, but it could be rat poison or something. they are solid pellets but to crush under pressure.
what's more interesting is how the heck did it get in there? there is no way these went through the pump. they would have trashed the pump for sure. the only possibility i can come up with is that the cap for the hydraulic reservoir must have been dislodged at some point and mice (or rats) were depositing them in the hole. but for that to work, the filter has to be on the suction side of the pump, which would not be what i consider "normal"
maybe this will fix some of the goofy hydrualic things i've noticed, like the loader not wanting to cycle sometimes.
anyway, thought some might find it interesting as well.
enjoy
enjoy
