I bought an '04 Odyssey a couple months ago and soon after discovered that it had a bad head gasket. It was also leaking oil profusely at what seemed like the rear main, so I opted to pull the block out of the van while I had the heads off to tackle seals and gaskets. I used all new seals (front crank seal, rear main, etc.) and for the oil pan, oil pump, and rear cover I used Permatex RTV. The front & rear covers I used RED high-temp, and for the oil pan I used the black stuff (just happened to be what I had at the time). New timing belt, water pump, slew of other stuff. Was not a quick project to say the least.
Finally got the van fired up yesterday and it runs like new, which it ought to after a $430 valve job on the heads, and all new gaskets/seals. I ran the van for 20 minutes or so, and I was floored when I noticed a puddle of oil underneath the passenger side of the vehicle. Looking up, it's dripping down the oil pan on the pass. side, pretty quickly I might add. It was a near steady drip, not a stream by any means. I can see oil directly behind the crank pulley, but it appears the lion's share of the leak is coming down the oil pan, definitely from above the oil pan seal, about an inch back from the crank pulley, but I can't tell where from. My best guess would be the oil pump, but I can't be sure. About the worst place it could be leaking, IMO.
Are there any common leaks that people experience when redoing these seals? I was pretty darn thorough, and took my time, so this has me stumped. Will I have to pull the whole engine out again for repair? For all this work, I left the subframe in place (I don't have a lift or the means to get the car real high) and pulled the engine out the top.
