I've used the Delcos, PureOne, Bosch in our 2.4L 2010 Equinox. All have performed well. I would get whatever you can get cheapest from Amazon or Rock Auto. The Delcos don't come with a new seal so I try to alternate between them and something else every other oil change.
Make sure you change the oil often. As long as it meets spec, frequency is more important than the particular oil. These engines dilute a lot of fuel, you'll smell it easily when you drain the oil. I follow the old recommendation of 3,000 miles which usually is about 50% left on the OLM. I had been doing 6,000 (which was still usually 30% left on the OLM, then they switched the programming on the OLM, but it was still about 10% left after the reprogram) and had a major engine repair (covered under warranty, barely) with the timing chain and tensioner, some valves, etc. No issues since going to shorter OCIs. Then again it has only been 25,000 since I began the shorter OCI.
These engines are incredibly easy to change the oil on. Make sure you get the Leslie oil cap low profile socket. PM me and I can send you the part number if you need it, sells for about $9 on Amazon.
