Oil drain plug design causes a mess.
by Rat407
05/29/15 08:43 PM
College assignment, need survey responses
by ClutchDisc
05/29/15 07:39 PM
Good Battery Life
by ecotourist
05/29/15 06:44 PM
2004 Yamaha V-Star 650, Amsoil 10w30
by ahemsa
05/29/15 06:31 PM
Need To Flush Out Pressure Regulator
by George7941
05/29/15 06:00 PM
Ice Cream Truck
by Cristobal
05/29/15 05:44 PM
Do enginners anticipate oil advances?
by zach1900
05/29/15 04:35 PM
Motorcraft FL-910s, 5k OCI
by BikeWhisperer
05/29/15 04:16 PM
Total Quartz ineo mc3 synth engine oil.
by rot
05/29/15 04:14 PM
engine oil called Total Quartz eneo mc3 synth
by rot
05/29/15 04:03 PM
just had a transmission oil change using ATF MV SP
by rot
05/29/15 03:50 PM
Sig P320
by Nyquist
05/29/15 03:39 PM
Kasakato, KironKid, John_M_J, winterdriver04, djwarner
54156 Registered Users
102 registered (AandPDan, 901Memphis, Astro14, AEHaas, andyd, 13 invisible), 1520 Guests and 103 Spiders online.
54156 Members
66 Forums
232025 Topics
#3744239 - 42 minutes 22 seconds ago Oil drain plug design causes a mess.
Rat407 Online   content
Loc: North Carolina
The oil plug on my CTD "Cruze Turbo Diesel" is one I have never seen before.
I can say it makes one heck of a mess, since as soon as you back it out two threads it starts to flow oil everywhere. We all know, diesel oil sucks being so black and it gets hot.
Anyhow, here is a picture of my drain plug. Just don't understand why GM designed it this way. Must be a reason. If I can put a Fumoto valve in, that is what I plan on doing. Just got to make sure it will work and not mess anything up. Can't see why it would.
On to the pictures.
#3744246 - 34 minutes 55 seconds ago Re: Oil drain plug design causes a mess. [Re: Rat407]
Chris142 Online   content
Loc: apple valley, ca
Looks like they don't want you to remove it.just unscrew it enough to drain.
02 Wrangler durablend 10w40
87 F250 Diesel Mystic 15w50
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Polaris Trailblazer delo 5w40
#3744249 - 30 minutes 31 seconds ago Re: Oil drain plug design causes a mess. [Re: Rat407]
Mr Nice Offline
Loc: USA
Remove oil fill cap, then loosen plug so it can drain without a mess.
2007 Civic EX
2006 Accord SE
2005 RSX base
2005 Civic LX
#3744254 - 22 minutes 31 seconds ago Re: Oil drain plug design causes a mess. [Re: Rat407]
Ethan1 Online   content
Loc: 'murica
From the vantage point of my armchair, it looks like the oil is supposed to flow down through it? Maybe it was designed by an engineer who pays someone else to change his oil...
#3744263 - 13 minutes 58 seconds ago Re: Oil drain plug design causes a mess. [Re: Ethan1]
Tegger Online   content
Loc: Canada
Or for the dealer tech who is going to loosen to drain, then move on to the vehicle in the next bay and come back a half-hour later, so he won't care how slowly the oil drains.
2013 Toyota RAV4 - 33,000 miles - Toyota 0W-20, Toyota filter
#3744264 - 11 minutes 43 seconds ago Re: Oil drain plug design causes a mess. [Re: Rat407]
Loc: North Carolina
I did vent the system by opening the fill cap. The mess is the oil flows back toward the oil pan as it hits the front of the plug coming out. so it was dripping from four different areas of the aluminum oil pan.
I found the Fumoto Valve that fits it. Going to order it and install on next oil change. I have the FV on my truck and Acadia and love it.
#3744266 - 10 minutes 3 seconds ago Re: Oil drain plug design causes a mess. [Re: Tegger]
Loc: North Carolina
That makes sense and they can put the catch pan right up next to the oil pan so it would not splash as bad. But for us DIMS'ers it makes a mess.
#3744270 - 7 minutes 41 seconds ago Re: Oil drain plug design causes a mess. [Re: Rat407]
GiveMeAVowel Online   happy
Loc: Stamford, CT
Actually I like this design, it appears they are trying to keep the oil from splattering outside the oil drain pan when it is being serviced.
