Originally Posted By: chrisri
Originally Posted By: Jetronic
Originally Posted By: Popsy
That would be the wise way. And I just changed the timing belt
looks like I'm screwed. But still a bit sceptical, there was no noise at all with 10W40!
you've only just changed the belt, the procedure is fresh in your head. NOW is the time to at least check the lifters and maybe replace the worst ones.
I wonder if he got that sound after cambelt change. Those are tricky without cam locks if never done before.
true, but I've seen a few with slightly off timing that had flat spots, but never one which developped a ticking sound. I have seen a few worn tappets though, and a fair share of worn variators (I don't believe the Barchetta has a variator on the intake) but those sound like a diesel usually.
Maybe it's the tensioner making the ticking sound, if there's too much or not enough tension.
