I want to give a public warning on the end results of this product:
I had a minor leak 3-4 drops overnight on my 1200 mile complete overhauled motor,
I want to prevent this issue getting worst so I start looking for a top quality stop leak, I ended up convinced by the extreme high priced for 8 ounce bottle of $65.00 the fancy web site and the convincing claims of the seller.I follow all the instructions & I add this PERMA-TECH into the motor, let it run for 20 minutes and shut it down as per the instructions.
Next morning I observe minor drippings around the oil pan area as well as near the front and rear of the motor. Checked oil level was almost 1/2 of a 1/4 low & I added that much. Perma-Tech indicates that stop leak will take effect after 150 continued drive or 200 miles under normal driving conditions, I took a 45 mile trip and stop to check, I freaked out as oil was dripping allover the place under the car and full 1/4 low and all these within 45 miles, To make the long story short I keep adding oil and keep driving to give it a chance to work to reach 200 miles, Now I already have 260 miles on it & Unfortunately my oil leaks have been increased by 400%, Perma-tech somehow has ruined the molecular structure of the seals and gaskets, I was told by the same expert that I should have use a regular stop leak that are available to all local stores and under $10.00 Contacted Perma-Tech recommend to sent me another bottle but have to pay $16.90 for shipping, What a play, Lesson learned: if the car leaks fix it period, I also found out that Perma-Tech & Dura-Seal is the same company under the ABX Cprp. Selling to victims like my self but I wasn't aware, Now you are aware thanks to Bob's site, by the way I have taken some close up pictures before and after if someone want this proof, just email me.
Regads to all
Yanis
Regads to all
Yanis
