Originally Posted By: spasm3
Originally Posted By: BlueOvalFitter
I don't understand why you, and others like you, just don't use the same weight oil during all seasons. I am not dogging you, or trying to be sarcastic, or even trying to ruffle your feathers. I mean, the oils you stated in the sentence I quoted, are so similar to each other that you can just pick one and use it all year round.
Ah well, if you sleep better at night doing it your way then go for it!
I am guilty of something similar; I always use a new oil filter at every OCI and some members dog me for that; the ones that think that at each OCI, instead of throwing the used oil filter away, use it again. And, my answer to that is,
"One Filter, One OCI!"
I don't take it as a dig, its a legitimate question. I'm simply following the owners manual. 2013 hydai elantra 1.8.
Chapter 8 page 5
"lower viscosity engine oils can provide better fuel economy and cold weather performance, however, higher viscosity engine oils are required for satisfactory lubrication in hot weather."
This above quote is straight from the manual. Since 5w20 is the lightest oil specified, I go by the chart that lists 5w30 as and acceptable oil, and even 10w 30 from O deg F and up.
Therefore i run 5w or 0w 20 winter and 5w 30 summer ( plus i have a about 3 changes of each weight i bought on clearance for $2.00 a quart.)
My trucks engine oil cap reads "5w20" oil. My owners manual reads to use 5W20 oil.
The Ford 4.2 V6 engine was built from 1997 until 2008. It was originally spec'd 5W30 oil in 1997 up until the year 2000. From 2001-2008 Ford recommended 5W20 oil, and back spec'd 5W20 oil for earlier built 4.2's as well. The 4.2's clearances and tolerances have stayed the same since it was first built in 1997 until it was put out of production in 2008. I currently have 5W20 oil in my engine now but have used both 5W20 and 5W30 since it was new. (6 miles)
