Originally Posted By: 2010_FX4
Originally Posted By: jk_636
All I do is continually prove that Purolator is still a quality filter. dont believe me? Take a look at any of my filters posted here. Case closed.
I was not aware that your filter not tearing negates all of the ones that have. I stand corrected.
Oh and one more thing, I am one of the few dedicated members who refuses to bow down to the Frampire nation and continue to show that there are actually more and in some cases better options out there besides the Fram ultra.
Really? Do tell what filter FOR THE MONEY is better than a FRAM Ultra and contains the same quality of construction?
Money and cost was never a variable for this discussion. If you are to cheap to spend a couple extra dollars on a filter then you don't really care about your engines well being and protection now do you?
Originally Posted By: IveBeenRued
jk_636, how did you determine that the Fram Ultra, RP, and Purolator Synthetic are in the same class? If I had to rank some of the top filters out there at this time I would do it as such (note: not an extensive list):
Fram Ultra rated at 20 micron @ 99% efficiency for 15K miles.
Amsoil EA rated at 20 micron @ 98.7 efficiency for 15-25K miles.
Mobil 1 rated at 25 micron @ 99.9% efficiency for 15K miles.
Purolator Synthetic rated at 25 micron @ 99% efficiency for 10K miles
Royal Purple rated at 25 micron @ 99% efficiency for an undetermined service interval
So if it were me and I wanted to test the top 3 oil filters I would personally drop the Royal Purple and the Purolator Synthetic because they are both outperformed by at least the Fram Ultra, Amsoil EA, and Mobil 1 oil filters.
Long and short of it:
A: Fram is rated greater than not at 20 microns. See ENTIRE discussion above. And I put absolutely NO stock in manufacturer claims to life expectency as every vehicle will be different and there are too many variables to be able to make an absolute claim of X number of miles. Although It is safe to assume that RP can go just as far as the rest if not farther based on media surface and thickness.
B: Amsoil filters are not readily available (that ridiculously ancient MLM nonsense) and Mobil 1 falls within the same efficiency range as the rest. Er go, Royal Purple, Purolator synthetic and Fram Ultra were the top three I chose to compare as they are readily available, same general price range and all contain synthetic media.
Feel free to do your own report on whatever filters you would like! I would like to read it!!
