Pick a good conventional motor oil like PYB or Formula Shell conventional. The add packs have a very good dose of Boron and Moly. Boron for cleanliness and Moly for anti-wear.
Action packed add packs in SOPUS products are really all you need. No additives are necessary.
In Turkey, I'm sure you have access to Shell Motor oil products.....they all have stout add packs.
Don't waste your money on stuff like this. Most if not all of these type of solids based products fall out of suspension a some point leaving deposits inside engine.
Instead of wasting your money on worthless snake oils use it to buy a better engine oil.
Its a decent oil, it doesn't need any help (or hindrance) from additives. Some aftermarket additives it is claimed by people who know a lot more then i can actually work against the additives already found in the oil.
