Originally Posted By: Ramblejam
Originally Posted By: Nick1994
You do realize this is on a truck right?
This is a F-150, with a curb weight of around 5,000lbs.
40% of that, or around 2,000lbs. is on the rear axle.
In other words, 1,000lbs. per tire.
According to the TRA flotation table, per tire (31x10.5R15LT):
25PSI - 1400lbs.
30PSI - 1595lbs.
35PSI - 1765lbs.
40PSI - 1945lbs.
45PSI - 2100lbs.
50PSI - 2270lbs.
So, unloaded @ 25PSI per rear tire, Dallas has 800lbs. of extra load capacity. Should he exceed this number, then he can adjust pressure accordingly.
Then again, this is just the Tire and Rim Association (standardizing body for the tire, rim, valve and allied parts industry for the United States) -- what do they have on Nick from Arizona, right?
Be certain to NEVER run those tires underinflated according to that table. If you ever increase the weight that they are carrying you must increase the pressure. This is especially true when you run them in hot weather on hot roads. If you ever apply more load and do not increase the pressure those tires will blow. Before they blow you may get a warning if you know what to look for. When the rubber over heats because of the combination of hot road way, hot air, over load causing too much flexing of the rubber, and underinflation allowing too much flexing, it will feel like the tires are sliding on ice. If you ever feel tires doing that you have to pull over and let them cool off, or they will blow out.
If you have to, run tires with more pressure than the load requires, such as when you are going to run them loaded up during one part of a trip, but not loaded up during another part of a trip. It is OK to run them over inflated sometimes, though you may not get the best ride from them when they are over inflated.
