Originally Posted By: gregk24
Can you describe the noise? Does it go away when warm? Does it get louder upon accelerating? I ask because some can confuse rod knock with piston slap, it can be hard to tell sometimes. My Accord has piston slap and it could be confused by some to be a "knock", but piston slap is pretty harmless.
Edit: also, what is the service history? How long have you owned it. It just seems odd for any car without a defect to get rod knock with such low mileage.
I was going to ask this, too. Spend some more time diagnosing to be sure what the problem is, then make a plan to fix it.
If it is a rod bearing, I wouldn't just replace the bearing and be done with it. It would probably fail again in a short time. If the crank journal is rough, or if the rod big end is mis-sized, the bearing won't survive. In this situation, getting a new crank and rod set may be the best way to go.
Another diagnostic question: Did the oil pressure decrease when the noise started?
