Originally Posted By: bubbatime
Originally Posted By: Donald
Does it really "require" or just "prefer". I think it just prefers high test gasoline. It may have more pep with high test but it will run fine with either.
“Your vehicle is designed to operate on premium unleaded gasoline with a pump octane of 91 or higher. If this octane grade is unavailable, regular unleaded gasoline with a pump octane of 87 or higher may be used temporarily. The use of regular unleaded gasoline can cause metallic knocking noises in the engine and will result in decreased engine performance. The long-term use of regular-grade gasoline can lead to engine damage.”
It's funny because most people really don't realize that many cars are designed to run on premium fuel, but due to modern computer engine management systems, they "can" accept regular fuel if "necessary". However, in any car that even hints about premium fuel being recommended or required, it is always best to use premium and follow that recommendation. Even though cars seem to run "fine" on regular where premium is specified, they are actually running with retarded ignition timing because they will knock under acceleration. You don't hear this knocking because the computer immediately retards ignition timing until it stops. The cycle happens over and over again while on regular fuel. Use of regular in these engines leads to reduced efficiency, increased fuel dilution, reduced fuel economy, and other domino effects as a result.
Some cars sold in N/A actually recommend or require premium elsewhere in the world, but only "need" regular here due to marketing reasons and the fact that most won't notice the downsides, especially if they never try the premium fuel.
