Please share your experiences and required tools with me.
What size of drain plug does it use? Does it come with a plastic cover for filter and oil pan (saw a video showing that, and you need to remove 3-4 extra bolts to get to the filter).
What wrench do I need to use to prevent rounding the drain plug (has that happened before and prevented my oil change trial).
So far I have: jack, and stands; 1/4 and 3/8 drive with sockets in both metric/english (craftsman 104 piece), oil filter wrench, 1/2 drive bolt out set (to remove damaged bolts).
Thanks so much.
Thanks so much.
