Reset KAM with tuner vs pull fuse vs disconnect battery
My 2012 Fusion (V6 3.0 FWD with 42k) has harsh shift problem. Although I plan to take it to the dealer to get it checked out. I wonder if resetting adaptive transmission like many Mustang owners do helps. If it is worth doing, what is the best way to do it? Of the three methods I mentioned in the title, do all of them require relearn (idle several minutes, turn on AC for one minute, then drive 10 miles)? I tried to use SCT X4 to reset KAM, but it throws CEL with DTC p1639. Maybe bricking the car is also a concern. Disconnecting battery definitely requires relearn, and it also resets radio and may cause other problems. Pulling a fuse seems to be the best way to me. Maybe it just resets adaptive transmission but not other parts of PCM? What is the counterpart in Fusion of fuse 47 of Mustang?
