Hi, our POS Honda has a rod knock after 100k. Besides the obvious of replacing a $1000 crank shaft in a tired engine. WHAT IS THE BEST HALF [censored] WAY TO QUITE IT DOWN? Honda specs 5w-20 for this poor engine,,
hansj3 said:What engine, what Honda? You could always try a hdeo, i mean the damage is done...
My uncle once sold a grand Marquis full of Lucus. [censored] thing barely started at 15 degrees, but no knock [/quote
Why would you need a new crank? Unless a bearing has spun the wear is probably isolated to the rod bearings, the crank may not even need turning.
What's the maintenance history on it? Is it an Odyssey van?
