JHZR2
Staff member
This is hopefully an easy/dumb question. For the sake of starting, assume that I DO NOT have an actual pressure washer. I do, but my question is for another reason.
Say all I have is a pressure washer rubber hose, gun, wand and nozzle. If I connected domestic (60 psi?) water up to it, would any practical amount flow? Remember, I'd be hooking domestic supply straight up to the hoses or wand, NOT going through a pressure washer pump.
Of course I won't get a huge, high pressure flow, but that's ok. Will it work at all? I know these things connect with quick connect couplings which may have a lot of pressure drop, plus a pretty small diameter hose.
But if I'm not looking for a ton of pressure, would this work and flow out through a nozzle, even if I modified a nozzle?
Thanks!
Thanks!
