Rear differential went out
SE Ohio
The wifes 2004 Grand Marquis had a pinion seal leak a year ago. Didn't notice anything until I started to hear a slight whine.
Changed the seal and fluid, but still had a slight whine at highway speed. Well it lasted another 35k. The wife said she heard a noise on her way home and the rear end started grinding.
I bought a used unit out of a wrecked 2006 with 25k miles on it to replace it. I'm going to have it filled with mobil one and hope to get another 165k out of it. At least a couple more years until she gets a closer job, to make it worth getting her a new one.
Otherwise this car is great. I don't have to add but maybe .5 quarts during the 7.5k OCI, trans shifts silky smooth. No rust. Hope this works out.
Originally Posted By: Falcon_LS
IIRC there was a recall on the rear differentials on '03-'04 MYs.
Yep, axle shafts were not properly hardened and the axle bearings would cut a nasty grove in the axle. Usually the axle seals leaking was the tell tale sign, but the amount of filings/debris in the oil probably ruins everything if run long enough.
The used axle should last a long time if you keep clean oil in it.
Yeah all of the civilian models had a 2.73, unless you get a performance package or police with a 3.27 - 3.55. It comes with a 3 month warranty.
I picked up a new pinion seal and two new u-joints to go with it.
Does taking the yoke off to change the seal affect preload? That may have caused the other failure ...
I have a leaky diff on the Cherokee. It uses the pinion nut to set preload. Unless I get it perfect, I'll lose the preload.
Not that it matters ... I had to take the yoke last year to replace it.
