stop with the sarcasm. I'm completely serious. My filter got wet. But I returned it, i told them the story and they gave me an exchange, accidents happen, life happens.
I'm assuming wrapping an opened wix filter, which no longer has a box top due to the oreilly rebate requiring the UPC is not good as the filter can oxidize and wrapping it would be better and prevent rust/the elements from impacting it and maintain its newness, right? What's the shelf life of an oil filter? Does it matter? Can a wrapped oil filter be used 10 years later and are the companies constantly changing/improving their filters so you want the newest one, even if it has the same part number? Let's say it's a fram PH3486
in ten years from now, is the farm PH3486 going to be the same or will it have been vastly improve? in other words, can you keep an oil filter stash and buy oil filters earlier as they're cheaper or should you buy the freshest filter possible? Thanks. or does filter age not matter?
