Hi All
Just done an oil change and now have quite a pronounced knock under load. For example moving off from standstill at low revs. I can also make it do this by blipping the throttle once and then again just before the engine returns to idle speed.
I seem to remember it making this noise before at various times but never as obvious as it is now. Oil used was the same Shell HX7 10w40 as before. The old stuff that came out had done just over 3k miles and was still relatively clean but just starting to turn brownish. I pre-filled the filter as best I could to minimise the low pressure at startup.
I know these engines can suffer from piston slap but it doesn't sound like that to me. I've tried to pinpoint where the noise originates from and it seems louder at the exhaust side towards the rear of the engine.
I may just run this stuff as a flush for a few hundred miles and dump it for something else. I'm thinking 10w40 magnatec or Mobil Super 2000.
Any advice appreciated
Thanks
Thanks
