Originally Posted By: A_Harman
Then once I've added the 100+ HP, bigger brakes become necessary, then bigger wheels to clear the bigger brakes, then more expensive tires to go on the bigger wheels, then improved rear suspension to put down the extra power, then improved front suspension to balance the handling...see how it snowballs.
...not to mention the requisite; fab 9 axle (so you can use a great diff like the Wavetrac, or Platinum Trac), watts link, decoupled torque arm (or are these the rear axle mods you implied??).
And then the STUPID money Penske/Moton/Ohlins/etc. multi-adjustable, reservoir dampers which could be
more than half of that 14 grand when all is said an done.
Then the aero and body mods to handle the square set up 335 section width donuts, carbon kevlar composite seats, built T56 Magnum and lightweight, triple disc racing clutch, and one is not too far from that $75K.
I'm thinking IRS conversion for the rear suspension. Get a rear suspension assembly from a wrecked Cam5 and graft it in. I'm not going to say you can't make a solid-axle suspension work well, but I will say if you start out with IRS, you're starting from a better place. IRS is the only thing about the Cam5 & 6 that really makes me envious.
Yes, IF the installation can be engineered correctly from a geometry/instant center viewpoint (a FEW have done a C4 IRS conversion).
I believe that Quaife makes their excellent, high bias diff for the 5th gen's (and probably for the 6th gens soon) center, or one can go to the 9" center conversions for the 5th gen IRS, and then use the Wavetrac diff.
