Originally Posted By: A_Harman
Originally Posted By: dailydriver
I read the info on the site, and yeah, the SS has the AFM/DOD on the LT1.
The cool thing is that they now use a Tremec 6 speed manual box in the non V-8 versions, instead of the Nippon nameplated Aisin units of the past.
I just HOPE that they do a larger displacement, NA, non-AFM/DOD, LT1 for the Z28 version, instead of just throwing a big Maggie/Eaton blower on it, a la the C7 Z06.
I was also hoping that this platform would be 450-500 lbs. lighter than the 5th gen, not just ~200, but every little bit helps.
AFM is here to stay. If you want an engine without AFM in the future, you'll have to delete it yourself.
Yes, I would like to see a larger displacement N/A Z28 in the future, but I hope they don't make it a $75,000 car. That's so un-Camaro-like. Camaro's are all about affordable performance.
Yes, sadly, I realize that you are correct about the AFM, and that is about the ONLY way we can have THIS type of V-8 performance in a CAFE driven world.
IF they can find a way to make more power without adding an Eaton/Maggie on top (and all of the ancillary weight and cost involved), that might keep the cost down at least a little, but once they start using; carbon fiber, titanium, aluminum alloys to try and pare more weight off of this platform (for the Z28 version), the cost goes right back on.
