dlundblad said:The OM says to use "approved" fluid./quote]
Don't believe the OM. That's just a corporate conspiracy to make your vehicle wear out sooner. Those GM engineers, with their thick glasses, white lab coats and college degrees - what do they know? ATF is magic. Put it in coolant to lubricate the water pump. Put it in the gas to clean the spark plugs. Put it in the motor oil to lubricate the valves. It also makes a great barbeque sauce. But don't put it in your transmission. It's not thick enough. 20w-50 racing oil for your electronic 6-speed tranny. Yeah, that's the ticket.
All the OM says is to use approved fluid. What is this fluid exacly? PSF or ATF? (That was my question in case you missed it. )
tightwad said:dlundblad said:The OM says to use "approved" fluid.
Then, go to any GM dealer and pick up some approved P/S fluid. Most auto parts stores carry approved GM P/S fluid(Prestone, Valvoline, etc.)
What others are saying is that, P/S fluid & ATF are essentially the same fluid!
Some P/S fluids such as Honda Genuine P/S fluid has proprietary additives and is also a synthetic but, is essentially a an ATF as well. I have used Honda P/S fluid in many-a-GM P/S u nits with great success
