In the last few weeks I've noticed the Focus trans becoming a little balky on the first few shifts in the mornings, which I thought was strange as its getting warmer out.
I did some searching and found that ATF can cause some bushings to stick when moved by the shift forks, bad enough to lock up the shifting completely. Now a couple years ago I bought the fancy XT-M5-QS full syn ford trans fluid for $25/quart and planned to change it myself, but things got busy and I had my wife take the car to a local garage to get the engine oil changed and change the trans fluid as well using the fluid I provided... She came home and the quarts of XT-M5-QS were gone, the car shifted well, so I thought everything was good.
But when I drained the trans this weekend, it was nice red ATF that came out instead of the amber XT-M5-QS... And of course that particular receipt didn't end up in the glove box file either.
The good news is that the ATF had very little darkening, so I think it didn't cause any catastrophic wear, and the trans is shifting quite well now with the proper fluid in it, so I think I'm in the clear.
I guess the lesson is to DIY, or atleast don't send someone else to get work done on the car that's not stupid simple.
I don't know if the mechanic at the garage kept my trans fluid on purpose, or maybe just set it aside and forgot to use it, but without the receipt I'm not going to bother accusing them of anything, but I'm not going back either.
To add some confusion, Ford did initially ship early focus's with ATF in the trans, but it lead to this problem and in 2001 they switched to the current fluid, so maybe they thought it was fine, or perhaps all-data said its OK.
