Originally Posted By: Kuato
carock, thanks for your experience.
OneEyeJack, what OCI do you use? (You may have put it in another thread but if so I missed it)
Based on UOA's I'm doing 10K with a NAPA Gold 1392 oil filter.
And I just received another message that Red Line is only good for track days. I think if they saw all the parts while I was doing the overhaul they might not think so. I replaced all the bearings just because I had the engine apart and had the new ones in the kit. The crank showed absolutely no wear. When you wiped your finger across the bottom of the oil pan there was no residue after sitting on the work bench a couple of days, just a light coating of oil that needed to be removed with solvent and a rag. There was no hint of sludge, anywhere.
