Originally Posted By: JHZR2
OTR diesels may be significantly different in turbo and lube design than consumer vehicles. I also doubt that OTR truckers instantly turn their engines off after slamming on the brake off an interstate offramp from an 80 MPH cruise.
I am not sure I have ever seen anyone with a diesel pickup or car just run down a off ramp and turn the key off either. A turbo cools down quite a bit just the coasting down the ramp and then driving down the street a ways and then to a stop. I have no problem taking my semi truck off the interstate under full load, down the ramp, to a stop, then down the street a little bit, into a truck stop lot, up to the fuel pump and turning the motor off. No serious cool down idling time. Took my 1996 Cummins N-14 to 1.4 million miles on conventional Kendall 15w40 without a turbo replacement. My 2006 Cummins ISX, I took to 968,000 on Allied 15w40 (a regional oil supplier label). It did need a new VG turbo at just over 800,000, but that centered around the actuator and not the turbo shaft or bearings that are directly involved with the oil.
The key is to have a pyrometer and take all the guessing out of the process. The design between the auto / pickup diesels and the commercial heavy trucks is strikingly similar.
