Fram uses a glass blended cellulose media while Purolator uses plain cellulose which requires more media to achieve the same holding capacity. The Fram gets the job done with less media.
Also your prices don't match up with everything I see locally, what is your price source?
Originally Posted By: DarthDuty
Air filters...? A fram at walmart is $7.50 and a puro at aap is 9.99. And I counted the pleats... Are you talking oil because im talking air.
Fram part # for my nissan is 4309
Yes sorry I thought I was in an oil filter thread!
Well will more pleats be better/worse? Air flow or filtration wise
Without knowing the efficiency or flow rate of the different media comparing pleat counts is useless.
I am pretty sure Fram knows what the oem filters need to be for flow, holding capacity and efficiency so they typically will meet or exceed those figures with whatever it takes.
