I hit 130K in my Accord today...YAY! I was waiting to hit that number before I changed my oil, planning on doing 5K OCI's from here on out pending UOA results. The oil was in for 5100 miles and some change / 7.5 months, the OLM was at 20% but certainly near 15% which is when it will alert you to change the oil out. This is the LONGEST I have ever gone, about twice as long as usual. I drained the M1 AFE 0w20 and put in TGMO 0w20 along with a fresh Fram Ultra XG7317. I do believe in pre-filling my oil filters, it filled this one to the brim and let the oil soak in well. Some oil did spill out when installing the filter but at least I knew it was full. Here is a little video I took to time how long it takes the oil pressure light to go off, honestly this isn't but a split second longer than it usually takes. Just wanted to share my experience, feel free to comment on yours! How long does it take your vehicle to build up oil pressure after an oil change?
Then I had to wash my car and clean the interior because I just couldn't give it a fresh oil/filter change and leave it semi dirty
I also filled up the gas tank with some V-Power for kicks.
