Hey all, I've got two oil samples since I last posted here. The first sample was using unknown oil, possibly Pennzoil 5w20. The last two samples were using Valvoline Conventional 5w30.
My prior sample seemed to have an issue with fuel dilution at 1.5%.
This went away with the latest sample, as the latest UOA found no detectable fuel.
My driving pattern changed a bit between samples; the lastest sample has fewer short (~5mile) trips compared to the other samples. Perhaps this is what caused the fuel dilution issue to go away?
Code:
Sample Sample Sample Universal Averages
OIL
MILES IN USE 2,200 2450 2,500 5,200
MILES 88,400 79,500 71,900
SAMPLE TAKEN 03/03/15 03/06/14 01/07/13
MAKE
ALUMINUM 1 2 2 3
CHROMIUM 0 0 0 0
IRON 3 4 4 7
COPPER 2 3 6 2
LEAD 0 1 2 3
TIN 4 0 0 1
MOLYBDENUM 4 5 212 65
NICKEL 0 0 0 0
MANGANESE 0 0 0 1
SILVER 0 0 0 0
TITANIUM 3 3 0 0
POTASSIUM 2 0 2 2
BORON 13 22 62 46
SILICON 6 7 5 16
SODIUM 282 273 9 25
CALCIUM 1742 1587 2397 2113
MAGNESIUM 12 13 20 138
PHOSPHORUS 751 702 776 706
ZINC 800 801 979 826
BARIUM 0 0 0 0
SHOULD BE
INSOLUBLES % .1 .3 0.2
WATER 0.0 0.0 0.0 0.1
FLASHPOINT ºF 385 335 410 >365
SUS VIS 210ºF 55.1 53.7 52.6 54-63
cSt @ 212ºF 8.81 8.38 8.07 8.5-11.3
FUEL %
Code:
OIL
MAKE
ALUMINUM 1 2 2 3
CHROMIUM 0 0 0 0
IRON 3 4 4 7
COPPER 2 3 6 2
LEAD 0 1 2 3
TIN 4 0 0 1
NICKEL 0 0 0 0
MANGANESE 0 0 0 1
SILVER 0 0 0 0
TITANIUM 3 3 0 0
POTASSIUM 2 0 2 2
BORON 13 22 62 46
SILICON 6 7 5 16
SODIUM 282 273 9 25
BARIUM 0 0 0 0
SHOULD BE
FUEL %
