Was wondering what oil weight and type oil for my road race 441 ci GM LS series engine you would use? Wet sump with oil cooler, Steel crank shaft with Hp clevite bearings, Steel h beam rods, Rod clearance at .022, mains at .025, high volume oil pump, pressure is at 80 psi now with 0w40 at max rpm 6700. oil temps at 250 max Would mobil1 0w40 be sufficient or go to the mobil1 15w50? Or what else you would recommend? I am looking for longevity not for every ounce of HP.
