Federated 5W20, 2500, 98860
NH
The 02 CRV was garaged & driven in NW OH 2500 mi during a 13 month period. It was mostly short tripped with an occasional 60 mi RT. Oil filter is unknown, but it’s probably a low cost one.
Code:
OIL 5W20 Federated
MILES IN USE 2500
MILES on veh 98,860
SAMPLE TAKEN 4/26/15
MAKE UP 0
ALUMINUM 2
CHROMIUM 0
IRON 3
COPPER 2
LEAD 1
TIN 0
MOLYBDENUM 62
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 120
SILICON 10
SODIUM 9
CALCIUM 1819
MAGNESIUM 6
PHOSPHORUS 674
ZINC 750
BARIUM 0
INSOLUBLES 0.3
WATER 0
FLASHPOINT ºF 345
SUS VIS 210ºF 50.4
cSt @ 212ºF 7.40
Fuel 0
Antifreeze 0
TBN 2.5
If the 0 fuel is correct, your engine smashed the oil.
If the flashpoint and viscosity are correct, then there's a fuel issue.
Good #'s. Another UOA reinforcing miles over time. You could have gone longer even though most people would be concerned that it's been over a year. Thanks for the post.
Good catch. The fuel should be 1.0%. Flashpoint of 345 shows some dilution.
ha ha your post made me laugh. Not bad for the wear metals though.
Makes good sense now...keep doing what you are doing IMO.
Try to get some heat in from time to time to get the fuel out.
Don't know...the OC was done at a local shop to a friend's car.
