Brakes are so variable. The swept area versus car weight determines what issues you face.
Most smaller cars tend to have very inadequate brakes IMO. I still see bicycle sized solid discs on the rear of many cars. These are cars where vigorous or abusive driving CAN and does overheat the rotors and help encourage pad deposits.
Higher performance cars and HD trucks with excess braking capacity have different issues, many times from the brakes never getting hot enough.
IME I have cracked drilled rotors. I have never cracked a slotted one. I have a "bling" set for my sig car with slots and drilled, too, but for real track days i run the factory slotteds only.
And finally, many here have always confused pad issues with rotor issues. It's pad material that is the important variable that determines most of the braking performance parameters, that rotor is just a heat sink...
