Honestly, I'd still run a shorter OCI if adding something like the product in the OP or Seafoam, etc. Even MMO was known for it's burn off effect over the course of an OCI when used to 'replace 1 quart' and you'd have to add back whatever flashed off at some point during the interval.
If using an idle flush, or something that requires 'some' driving I don't see the point in going too long. Whatever it might clean, it's not going to clean any further and you may overload the current fill towards it's capability to suspend since the purpose is a shorter-cleaning interval.
IIRC, Seafoam used to state a max of 500 miles of driving if you added to the crankcase. So, regardless if he didn't drain right away I'd still change the oil after a couple fill ups. The number may be 1,000 miles.
