Originally Posted By: Pontual
Fuel pump check valve defective, the fuel from engine leaking back to tank.
You can easily verify this. Cycle your key several times to the "run" position, then try starting it. If it starts very quickly, the check valve is one possibility. Leaky fuel injectors can do the same.
