I'm sensing I may be getting myself in trouble with an old Corvette for sale I'm considering.
It is equipped with the "Doug Nash" 4+3 manual gearbox. Im trying to learn about it, and it seems to be an odd duck to say the least. This manual was offered by GM in Vettes from 1984-1988. It used the proven Four Speed Manual coupled with an automatic(!) which could give you a total of 7 forward gear ratios, although I've heard most guys just left it off until they were on the highway, flipped the switch in 4th gear, essentially using it as a 4+1...Anyway, Ive read different accounts advising the transmissions are anywhere from total junk to pretty neat as long as maintained by the book. Thing is, Ive read that many people did not change the auto OD mercon fluid and filter out of ignorance, causing failures. There is also controversy on how to shift into OD, whether to flip the switch with the clutch in or out...
I have the chance to purchase a low mileage example (relatively) cheap. It works ok, but the service history is unknown. Id like some experienced opinions on this gearbox, how hard it is to service, and if I should just walk away from this car with its "oddity" conglomeration of a transmission ....
