I could use some help choosing a grease. I bought a new tractor and this is what it calls for as far as chassis lube. To me it reads like Greek.
" Use a good grade of grease designed for pin and bushings on agricultural equipment. Lithium or aluminum complex type grease with high viscosity base oil, tackiness, and molybdenum disulphide are suitable. Grease approved for NLGI certification GC-LB are recommended.
Grease must be SAE Multipurpose High Temperature grease with Extreme Pressure performance and capable of operating at assembly temperatures above 302 deg F.
Any help would be appreciated, looking for something that is widely available, so I can stick to one brand.
Thanks
Thanks
