Shovelhead, unknown miles, over 20 years since last top end, with the heads off you can rattle the pistons around in the cylinder bore. No cylinder wall scoring, slight discernible cross-hatch remaining, rods are clearly not bent or twisted, motor looks and sounds great, it is just flat wore out.
Been running Rev-Tech 20w-60 which seemed to be an improvement over 20w-50, but the motor got really loud, by the end of last summer I thought it was rebuild time for sure.
Thought it couldn't hurt to try, drained out the black and nasty 20-w60 and put in 4 quarts of Kendal straight SAE 50 in. The difference is amazing. Ring seal is good, minimal smoking, valve train and piston slap quieted right down, I think I'll see if she can go another year.
Any ideas why?
Also, how come some aircraft oils but not others result in accelerated cam wear in old Harleys? AeroShell seemed to work pretty good, others, not so much. Lost the cam lobes in no time.
Any ideas why?
