Originally Posted By: VNTS
what type of flush do you use?? I assume something you add to the old oil, idle 15 minutes and drain, change filter and refill with fresh oil?
What kind of oil do you use in your 4.7?
Originally Posted By: jk_636
Originally Posted By: donnyj08
Every oil change?? Lol ge'ez man. I'm just now contemplating doing a treatment on my 176k mile armada.
I was probably overthinking it. The armada always gets 8-10k mile changes so I was leery of chemical being left over in the oil for 10k miles or so. Thanks for the replies
I have done one every oil change since the vehicle was practically brand new. It now (9 years and 100k miles later) still runs like a champ and the crankcase is clean as a whistle.
You will be fine. I will give you a word of warning though, your vehicle can be past the point of no return. If your motor is super sludged, you could do more harm than good. I would look at 5 minute motor flush as a routine / maintenance cleaner. If you have too much sludge in the motor, it could break some free and cause more harm than good. For severe sludge, you would have to pull valve covers and oil pan and get to cleaning!
Honestly whatever is on sale. Right now it is Mobil 1, Mobil 5000 before that, and Motocraft semi synthetic before that and on.
I add the can. Run for 5-10 minutes. Then drain completely. Change filter. Add new oil. And back to the races!
