I know with other cars that have the canister up under the hood. If charcoal comes out of them they are bad.
However, with the rear mounted canisters used on the subarus. Is it normal/ok for charcoal to come out if it's shaken or is that a sign of a bad canister? My canister looks perfectly fine. The holes on the inside of the canister are rather large which allows for the small charcoal pieces to come out if shaken.
Anyone know if it's ok on Subaru canisters to have charcoal come out or is that a sign of a failed canister.
Everything looks good. I'm not getting any check engine lights. Only had it off because I was getting a gas smell sometimes when the car is shut off. I found a hose that was lose which I believe was the problem. Just wondering if I should replace the canister or not due to charcoal coming out.
Thoughts?
This is what mine looks like. Located all the way in the back of the car.
Thoughts?
