Originally Posted By: Trav
The return line to the reservoir is low pressure so if you want to fix it you can if its a nightmare to change (like have to lift the engine) the line.
Use PS or AFT rated hose not fuel line and fuel injection hose clamps with barb fittings.
If it doesn't require any special long drawn out time consuming procedure just change it.
This! ^^^ I have done this many times in the past on return lines ONLY(NOT High Pressure Line). Usually make my own and they last for years!
