Make/Model: GM 5.3L V-8
Vehicle: 2004 Chevy Tahoe
Mixed in a few quick OCI with the OE line to see if metals and silicon would come down. Still can't find the silicon entry point, but have gotten check engine light 2-3x recently for MAF. Switched from K&N, Wix, and now to Amsoil air filter with no noticeable change in values. Also replaced the air box itself during this last run, check engine light has tripped since then as well.
Blackstone comments:
Silicon is higher yet in this sample, but considering how great wear is we really don't think it's from a harmful source like abrasive dirt. It's not an additive in the oil, since it increased and this is the same oil as last time, so it might just be from a silicone sealer of some sort. We're not sure what to make of the slightly high viscosity, but it's not hurting anything so it's just something to point out. The TBN of 3.1 shows that this oil still had some active additive left. This engine looks to be in good shape as it approaches the big 200K mile-mark, so try 9K miles next time.
Code:
OIL Ams SS Ams SS Ams OE Ams OE Ams SS Ams SS
MILES IN USE 8,124 6,069 3,165 3,008 9,569 7,990
MILES ON UNIT 177,436 175,381 169,312 166,147 163,139 161,560
SAMPLE TAKEN 11/30/14 10/23/14 6/23/14 5/6/14 1/25/14 12/18/13
MAKE UP OIL 0 0 0 0 0 0
ALUMINUM 3 2 2 3 5 5
CHROMIUM 0 0 0 1 1 0
IRON 9 7 3 7 18 15
COPPER 12 10 6 12 14 14
LEAD 7 6 2 5 14 12
TIN 0 0 0 0 0 0
MOLYBDENUM 144 139 68 89 132 132
NICKEL 0 1 0 2 1 1
MANGANESE 0 0 0 0 1 1
SILVER 0 0 0 1 0 0
TITANIUM 0 0 0 0 0 0
POTASSIUM 0 0 0 1 2 2
BORON 45 53 105 147 49 54
SILICON 31 25 14 18 25 25
SODIUM 9 8 3 7 10 10
CALCIUM 3247 3475 1944 2284 3195 3072
MAGNESIUM 12 15 8 10 13 13
PHOSPHORUS 702 658 658 790 644 661
ZINC 801 767 747 875 690 692
BARIUM 0 0 0 0 0 0
SUS @ 210F 64.6 63.8 58.7 58.3 62.9 62.2
Visc @ 100C 11.51 11.29 9.86 9.73 11.04 10.84
Flashpoint 430 435 410 430 445 420
Fuel %
Antifreeze % 0.0 0.0 0.0 0.0 0.0 0.0
Water % 0.0 0.0 0.0 0.0 0.0 0.0
Insolubles % 0.4 0.3 0.1 0.2 0.6 0.3
TBN 3.1 3.4 2.4 2.4 2.8
Code:
IRON 9 7 3 7 18 15
LEAD 7 6 2 5 14 12
TIN 0 0 0 0 0 0
NICKEL 0 1 0 2 1 1
SILVER 0 0 0 1 0 0
BARIUM 0 0 0 0 0 0
Fuel %
