Hey guys,
I have a quick question since I am performing my 30k maintenance. I have a 2013 Tacoma 2.7L manual transmission 4x4.
I have done the following so far.
1. Drained rear differential fluid. Filled it back up with Redline 75w90 gear oil until it started to drip out the fill hole. I let it drip out and replaced the fill plug. It took just a tiny bit more than 3 quarts.
2. Did the transfer case the same process as the rear diff but with Redline MT-90. It took just over 1 quart before coming out the fill hole.
3. Did the same process to the manual transmission with MT-90. It took roughly 2.5 quarts.
I will do the front differential the same way if this is the correct process. Also, can I leave the redline in there longer than 30k? That seems way short to me for synthetic fluid. But I don't really know.
I also changed the oil with TGMO 0w20 and the air filter.
Thanks guys.
Thanks guys.
